changes for next PETSc release
Lisandro Dalcin
dalcinl at gmail.com
Mon Mar 17 13:26:54 CDT 2008
Well, Fortran 90 modules provide a sort of namespace support, I think.
On 3/17/08, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Fortran90 has namespaces??????
> On Mar 17, 2008, at 12:59 PM, Matthew Knepley wrote:
> > On Mon, Mar 17, 2008 at 12:27 PM, Barry Smith <bsmith at mcs.anl.gov>
> > wrote:
> >>>> 2) properly name-space PETSc by putting a Petsc in front of all
> >>>> PETSc
> >>>> objects, function names etc
> >>>> (this will require changing a few names also to keep them below
> >>>> the 32 character limit). This will
> >>>> be very painful change for some users who are not comfortable
> >>>> ever changing code, hence I hesitate
> >>>> to do it, but it is the right thing to do and should have been
> >>>> done originally.
> >>> I guess I still do not see the need for this. NIMROD is a not a
> >>> sufficient
> >>> driver in my mind.
> >> You are an elitist who thinks that important ideas can only come
> >> from important/smart people. This I disagree strongly with, one
> >> should
> >> look everywhere, even at the local dump, for good ideas. NIMROD is
> >> not the driver, it is merely the spark.
> > I will be more specific. I think there is no good idea connected
> > with this
> > requirement of NIMROD. In fact, I think it is a very very bad idea.
> > They are
> > using a language with namespaces (F90) but they ignore them. Then they
> > wonder why uses a product from a language without namespaces (C) they
> > have a problem. The wrong strategy is to do something complicated in
> > the
> > deficient language. The right thing to do is something easy in the
> > language
> > with support.
> > Why can't we just do an F90 binding with namespaces? That would fix
> > NIMROD
> > and not disrupt the community who has not complained (and who is much
> > much bigger).
> >>> If we really want namespaces, use a real language that
> >>> has namespaces. There are plenty. If we are still using C, I say we
> >>> stick
> >>> with the old division. The imposition of this much pain on the
> >>> overwhelming
> >>> majority of users seems unjustified.
> >> You seem to be saying we should stick with a bad decision I made
> >> many years ago, just because it is painful to change. When did you
> >> suddenly become conservative?
> > No, I am saying that the fix is crap because it is complicated,
> > entails
> > enormous changes to the code, and is ugly. I think the correct fix is
> > to use nice mechanisms in languages that support them, like C++.
> > I am completely against forcing weak language mechanisms to do
> > complicated things, which is why I hate all those template tricks.
> > Also, we should look at history. We have made mistakes in the past
> > when changing the interface (KSPSolve() with no arguments) which
> > were painful. I want to make sure what we choose to do is as simple
> > and non-painful as possible.
> > Matt
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
