#define XXXType const char* ----> #define XXXType char* ?
Barry Smith
bsmith at mcs.anl.gov
Mon Jun 23 14:25:43 CDT 2008
A while ago I made XXType (MatType, VecType etc) const char*
I now think that was a mistake. I'd like to change them to just
char* XXType and change the prototypes
XXXSetType(XXXXX x,XXXType t) ------> XXXSetType(XXXXXX x,const
XXXType t)
XXXGetType(XXXXX x,XXXType *t) -----> XXXGetType(XXXXXX x,const
XXTYPE* t)
Can anyone suggest a technical reason why this is a bad idea before
I push the code?
I will warn before I push so that if you are in the middle of some
delicate coding and are afraid this
will break things you can avoid pulling for a while.
Thanks
Barry
Note this means if you have code like
VecType t = VECMPI;
you would need to change it to
const VecType t = VECMPI;
