using MUMPS with mg
    Lisandro Dalcin
    dalcinl at gmail.com
    Mon Jun 23 13:16:48 CDT 2008
On 6/23/08, Thomas Geenen <geenen at gmail.com> wrote:
> i will check if just adding
>  ierr = MatConvert(A, MATAIJMUMPS, MAT_REUSE_MATRIX,&A);CHKERRQ(ierr);
>  will do the trick
Indeed. That would do the trick. But perhaps better is to add:
MatConvert(A, MATSAME, MAT_REUSE_MATRIX,&A)
Then, you can pass '-matconvert_type aijmumps' (check for the actual
option name, to busy right now to look at the source) to actually use
MATAIJMUMPS. If you do not pass the option, the the MatConvert() call
is just a non-op .
Perhaps this is a candidate for petsc-dev? Or MatSetSolverType() will
handle this in the near future?
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
