some fixes for AIJ and BAIJ matrices
Tue Jun 10 15:44:02 CDT 2008
   Beats the heck out of me, do whatever fixes you feel are needed.
    Barry
On Jun 10, 2008, at 10:05 AM, Lisandro Dalcin wrote:
> Some fixes are needed for BAIJ matrices are:
> (1) MatMPIBAIJSetPreallocationCSR_MPIBAIJ   ->  BROKEN
> (2) MatSeqBAIJSetPreallocationCSR_SeqBAIJ  ->  MISSING
> Regarding (1), the fix needs to call PetscMapSetUp() for setting-up
> the row and column maps (rmap&cmap fields) at the very begining,
> before anything else. If this is not done, the stuff is the row/column
> maps are not properly initialized at the point (1) is called. But
> then, PetscMapSetUp() will be called again as (1) calls
> MatMPIBAIJSetPreallocation_MPIBAIJ with nnz information. However, I
> believe this is not an issue, as the second call will be a no-op (at
> least for optimized builds). Additionally, there is a bug at the point
> MatSetValuesBlocked_MPIBAIJ() is being called, as the block-size is
> not being taking into accout for the 'values' array (when it is
> provided).
> Regarding (2), the issues in (1) for rmap/cmap are the same.
> It is fine to push the fixes in release-2.3.3, particularly regarding
> that (2) could be seen a 'new functionality'? I would prefer to add it
> to release-2.3.3.
> Finally, for MPIAIJ, something I'm not sure what to do is the
> following:
> - for MatSeq[B]AIJ one can pass nz=MAT_SKIP_PREALLOCATION
> - for MatMPI[B]AIJ, passing d_nz/o_nz=MAT_SKIP_PREALLOCATION generates
> an error.
> Should MatMPI[B]AIJ support MAT_SKIP_PREALLOCATION for d_nz/o_nz
> arguments?
> Again, it is fine to push this to release-2.3.3 ?
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
