problem with PetscSynchronizedFPrintf (fwd)
Matthew Knepley
knepley at gmail.com
Mon Jul 21 14:47:36 CDT 2008
I made this change because synchronized printing was cutting off my
stuff. Now the queue is dynamically allocated so it can accomodate
any size string.
I tried ex7 and it runs fine for me, even under valgrind.
Shi, can you reproduce this with a Sieve example?
Matt
On Mon, Jul 21, 2008 at 2:37 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Looks like this could be related to changeset 9e3fbe04a926
> --> mprint.h <--
> - char string[QUEUESTRINGSIZE];
> + char *string;
> So now strings needs to use malloc()/free()?
> Matt - you can reproduce this issue with dm/ao/examples/tests/ex7.c
> Satish
> On Mon, 21 Jul 2008, Satish Balay wrote:
>> ---------- Forwarded message ----------
>> Date: Sun, 20 Jul 2008 22:39:13 -0700 (PDT)
>> From: Shi Jin <jinzishuai at yahoo.com>
>> Subject: problem with PetscSynchronizedFPrintf
>> To: petsc-dev at mcs.anl.gov
>> Hi,
>> I recently updated my petsc-dev and found my previously working code is having trouble running in parallel. I've narrowed it down to the calls to PetscSynchronizedFPrintf. Even if I don't have those, I will have errors at the end of my MPI runs like:
>> [1]PETSC ERROR: PetscMemzero() line 189 in src/sys/utils/memc.c
>> [1]PETSC ERROR: PetscViewerASCIISynchronizedPrintf() line 859 in src/sys/viewer/impls/ascii/filev.c
>> [1]PETSC ERROR: PetscMemoryShowUsage() line 367 in src/sys/memory/mtr.c
>> [1]PETSC ERROR: PetscFinalize() line 675 in src/sys/objects/pinit.c
>> [1]PETSC ERROR: completeSection() line 163 in main.cxx
>> [0]0:Return code = 0, signaled with Interrupt
>> [0]1:Return code = 85
>> Since the same code was running fine before the update. I am wondering if it is something recently introduced.
>> Thanks a lot.
>> Shi Jin, PhD
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
