config/configure.py -> configure?
Boyana Norris
norris at mcs.anl.gov
Thu Jul 17 15:58:56 CDT 2008
Speaking of configure and user experiences, I just noticed that PETSc
defines top_builddir (in petscconf), which conflicts with
automake-generated makefiles, making it impossible in some cases to
include PETSc's petsconf file into Makefile.am (as far as I know that's
the only thing that causes problems). I hate automake in general, but
sometimes you are stuck with it and it's very nice to be able to include
PETSc make snippets even in automake files and avoid a lot of pain.
Anyway, since this is in a file that gets copied to the install
location, I think in general it would be best to avoid defining build
tree-related variables (especially those that conflict with
auto-generated ones from other tools). Thoughts?
Boyana
Satish Balay wrote:
> On Thu, 17 Jul 2008, Satish Balay wrote:
>>> If we could support the same way that this is done with autoconf packages
>>> that would improve a users experience with PETSc.
>> I guess we don't prevent the usage from shell scripts. We just promote
>> the alternative usage of adding configure options in a python script.
> And we generate $PETSC_ARCH/config/configure.py - which can be rerun
> by the user. Alternative would be to generate this file in a
> shell-script notation..
> Satish
Boyana Norris, Computer Scientist | Email: norris at mcs.anl.gov
Argonne National Laboratory | Phone: +1 (630) 252 7908
http://www.mcs.anl.gov/~norris/ | Fax: +1 (630) 252 5986
