SELinux
    Satish Balay
    balay at mcs.anl.gov
    Mon Jan 14 15:47:21 CST 2008
I had this problem with both gcc & intel compilers with selinux
enabled.
Now I don't see it anymore. Its strange. [well there were some
selinux-policy updates on my Fedora8 box - since I made these
changes..]
Yeah - if chcon is not necessary - we shouldn't use it. I'll remove my
changes for now and see if these problems resurface..
Satish
On Mon, 14 Jan 2008, Lisandro Dalcin wrote:
> The very funny error below:
> libpetsc.so: cannot restore segment prot after reloc: Permission denied
> should NEVER occur if source code is correctly built (using -fPIC or
> equivalent) and good programming practices are followed.
> Can someone (Satish?) comment the specific scenario where this issue
> arised? I believe it would be better not to depend on 'chcon' to get
> things workig, but make sure all source code is compiled and written
> as it should be. However, I believe this can still cause problems when
> building a sharedlib PETSc with a staticlib pre-built external
> package.
