snes/examples/tutorials/ex19 with 2 processors leaking communicators
Lisandro Dalcin dalcinl at gmail.com
Tue Dec 9 07:54:51 CST 2008
I'm using mpich2-1.1a2 built with debug (passing --enable-g=all to
mpich2's configure).
When running snes/examples/tutorials/ex19 with 2 processors, I get the
following lines in the output:
In direct memory block for handle type ATTRIBUTE KEY, 6 handles are
still allocated
In direct memory block for handle type COMM, 3 handles are still allocated
In indirect memory block 0 for handle type COMM, 3 handles are still allocated
[1] 24 at [0x084a4fb0], mpid_vc.c[63]
[1] 8 at [0x08301438], local_proc.c[364]
[1] 16 at [0x0837b7f8], mpid_vc.c[63]
still allocated
In indirect memory block 0 for handle type COMM, 8 handles are still allocated
[0] 16 at [0x09be9670], mpid_vc.c[63]
[0] 8 at [0x09aec918], local_proc.c[363]
[0] 16 at [0x099ff400], mpid_vc.c[63]
The ATTRIBUTE KEY leaks are expected, PETSc does not frees all created keyvals.
But the others, those related to "COMM", are unexpected. Moreover, the
full petsc4py testsuite does not show those warnings, not ex19 with 1
proc or ex5f with 1 proc (both also run by 'make test'). So I suspect
that DMMG code (or the ex19 code) is leaking communicators.
If someone of you have a bit of time, please look at this.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
