I really like "const" usage, but isn't this too much?
Lisandro Dalcin dalcinl at gmail.com
Wed Dec 3 19:40:01 CST 2008
Barry, are you talking about Vec's of local size zero? Damn me! I
completelly forgot this case... But then, will not it be better to
check and special case zero local sizes ??
On Wed, Dec 3, 2008 at 10:37 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On Wed, Dec 3, 2008 at 9:17 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   That is wierd; it seems strange that it would even compile.
> OK, I'll try to review all this tomorrow, there are some other weird
> Vec calls with such "const".
>>    BTW: I think your new change
>> 7 - v->unplacedarray = v->array; /* save previous array so reset can bring
>> it back */ 8
>> - v->array = (PetscScalar *)a; 9 +
>>  if (a) { 10 + v->unplacedarray = v->array; /* save previous array so reset
>> can bring it back */ 11
>> + v->array = (PetscScalar *)a; 12 + }
>> is TOTALLY wrong.
> You see, I should never push before commenting :-(
>> It is perfectly legitimate to place null arrays and one
>> wants
>> them to behave just like regular place arrays (saving the previous array).
> What's the use case? This is used internally in PETSc? I do not remember...
>> Why did you make this change and what was wrong with the way it was?
> Do you mean that it is legitimate taht if a user makes the nasty bug
> of calling VecPlaceArray(x,ptr) with ptr being NULL, then next he/she
> will get a nasty segfault when calling Vec operations (let say,
> VecMax()) ???
> Barry, feel free to revert the changeset. Anyway, please let me know
> the rationale for this "feature", I still do not get it...
>>  Barry
>> On Dec 3, 2008, at 4:45 PM, Lisandro Dalcin wrote:
>>> VecPlaceArray(Vec vec,const PetscScalar array[])
>>> VecReplaceArray(Vec vec,const PetscScalar array[])
>>> Lisandro Dalcín
>>> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>>> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>>> Tel/Fax: +54-(0)342-451.1594
> Lisandro Dalcín
Lisandro Dalcín
