column map in Mat MPIAdj
Lisandro Dalcin
dalcinl at gmail.com
Wed Dec 3 14:06:04 CST 2008
On Wed, Dec 3, 2008 at 5:28 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> The normal pattern (for example MPIAIJ, MPIBAIJ) is for the PetscMap setup
> being done in the associated MatXXXSetPreallocation() routine.
> I think the correct fix is
> 1) change the ierr = MatSetSizes(*A,m,n,PETSC_DETERMINE,n);CHKERRQ(ierr);
> in MatCreateMPIAdj to ierr =
> MatSetSizes(*A,m,PETSC_DECIDE,PETSC_DETERMINE,n);CHKERRQ(ierr);
Yep, this seems to be fix. I believe I'll even change the name of the
'n' argument to 'N' and put it VERY clear in the docs that 'N' is de
global number of columns.
> 2) remove the two lines
> if (B->cmap->n < 0) B->cmap->n = B->cmap->N;
> if (B->cmap->N < 0) B->cmap->N = B->cmap->n;
> from MatCreate_MPIAdj()
> 3) either add the ierr = PetscMapSetUp(B->cmap);CHKERRQ(ierr); to
> MatCreate_MPIAdj() OR put the PetscMapSetUp() for both rmap and
> cmap into MatMPIAdjSetPreallocation() [this would be best cause it matches
> the pattern of the others]
I agree. Let's setup the maps in MatMPIAdjSetPreallocation().
> Or am I missing something.
> Barry
> The business of setting the local column size to the global column size came
> from
> long ago and probably makes no sense any more.
> On Dec 3, 2008, at 9:36 AM, Lisandro Dalcin wrote:
>> Sorry, my comment about PETSC_COMM_SELF was a nonsense :-(
>> Let me write the rule in C-Python-pseudocode
>> rank = mat->comm->rank
>> size = mat->comm->size
>> cmap->N = # total_columns
>> for p in range(size):
>> if p == rank:
>> mat->cmap->n = cmap->N
>> else:
>> mat->cmap->n = 0
>> # and finally
>> PetscMapSetUp(mat->cmap)
>> That would be fine?
>> On Wed, Dec 3, 2008 at 1:19 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>>> Can someone help me to review this routine?
>>> MatCreate_MPIAdj(Mat B)
>>> I understand that MATMPIADJ is rather special, but the call above is
>>> never made
>>> then It seems that some stuff (ranges) in the column map will be
>>> uninitialized.
>>> What values should have the entries in "cmap" for mpiadj matrices?
>>> Should the "comm" in "cmap" be MPI_COMM_SELF, then we can call
>>> PetscMapSetUp?
>>> Lisandro Dalcín
>>> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>>> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>>> Tel/Fax: +54-(0)342-451.1594
>> Lisandro Dalcín
Lisandro Dalcín
