Inner KSP never created on SNES
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Dec  2 08:47:45 CST 2008
On Dec 2, 2008, at 8:43 AM, Matthew Knepley wrote:
> On Tue, Dec 2, 2008 at 8:41 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>   Matt,
>    You are wrong!
>    I will fix this today.
> Okay, thats fine. For hg, you can do annotate on the file to see
> what lines
> come from what version,
    I want to find when lines DISAPPEARED, not appeared! And I want a
simple
search mechanism to find it not, not to have to manually hunt through
a bunch of
annotated files till I see it gone.
   The search in hg view seems like useless garbage.
    Barry
> and also log to see which sets changed it. You can
> also search in hg view.
>   Matt
>    Barry
> On Dec 2, 2008, at 8:29 AM, Matthew Knepley wrote:
> I am not against requiring SetFromOptions() to create default
> objects. We
> already require it to set a default type.
>  Matt
> On Tue, Dec 2, 2008 at 8:08 AM, Lisandro Dalcin <dalcinl at gmail.com>
> wrote:
> I've just noticed that now SNES does not create the inner KSP at the
> time SNESCreate() is called. Then I could easily manage to break
> things (basically, if SNESSetFromOptions() is never called)
> Does it make sense to add:
> if (!snes->ksp) { SNESGetKSP(snes, &snes->ksp);}
> near the begining of SNESSetUp() ??
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> -- Norbert Wiener
