adding macro in petscversion.h
Satish Balay
balay at mcs.anl.gov
Mon Dec 1 09:51:37 CST 2008
On Mon, 1 Dec 2008, Lisandro Dalcin wrote:
> It it is not too late, I would like to add the following macro in petscversion.h
> #if !defined(PETSC_VERSION_)
I think there should not be this #if test. [Its more appropriate for
petsc4py to check for this flag and redefine for old petsc versions].
> #define PETSC_VERSION_(MAJOR,MINOR,SUBMINOR) \
> (PETSC_VERSION_MAJOR == MAJOR && \
> PETSC_VERSION_MINOR == MINOR && \
> PETSC_VERSION_SUBMINOR == SUBMINOR && \
> PETSC_VERSION_RELEASE == 1)
> #endif
> In petsc4py, I have to test the version in many places in order to
> provide backward compatibility with previous releases. The new macro
> is really handy for this,
> #if PETSC_VERSION_(2,3,2)
> /* code for the 2.3.2 case */
> #elif PETSC_VERSION_(2,3,3)
> #elif PETSC_VERSION_(2,4,0)
> /* code for latest release (once done)*/
> #else
> /* code for (future) petsc-dev
> #endif
> What do you think? Should I remove the last "_" in "PETSC_VERSION_".
> Better name?
Barry likes the _ version of the names. They cause problems with
fortran interface - so I don't prefer it. However in this case - this
macro remains a cpp directive - so no fortran interface issue - so
this name is fine by me..
So - its ok by me - to push this new macro..
thanks,
Satish
> Of course, it I want to use this for 2.3.2/2.3.3 releases, I would
> need to manage that in my code, but from 2.4.0 and above, that would
> be already defined for user convenience needing to target the same
> code for multiple PETSc releases.
