adding SNESSetLinearSolve()
Matthew Knepley
knepley at gmail.com
Mon Oct 29 12:54:16 CDT 2007
You might want to investigate FeasNewt from Todd Munson, which is
a very elegant solution of this problem.
Matt
On 10/29/07, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> Some time ago I made a request for adding SNESSetLinearSolve(), in
> order to let users set a custom linear solve routine to SNES. I was
> not clear to me if this idea was finally accepted, so I want to ask
> again.
> I really needs this feature in the near future, I I would like this to
> go in the next petsc release. My use case is rather simple: I'm
> helping a coworker to use SNES for solving a nonlinear optimization
> problem related to mesh movement (that is, move nodes retaining
> element connectivities). This problem uses a regularized functional,
> wich introduces a global degree of freedom coupled with all others
> dofs. To avoid assembling a sparse parallel AIJ matrix with a dense
> column and row, we endup needing to solve two linear systems with the
> same matrix for actually solving the Hessian of the regularized
> functional.
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
