adding SNESSetLinearSolve()
    Lisandro Dalcin
    dalcinl at gmail.com
    Mon Oct 29 12:04:03 CDT 2007
Some time ago I made a request for adding SNESSetLinearSolve(), in
order to let users set a custom linear solve routine to SNES. I was
not clear to me if this idea was finally accepted, so I want to ask
again.
I really needs this feature in the near future, I I would like this to
go in the next petsc release. My use case is rather simple: I'm
helping a coworker to use SNES for solving a nonlinear optimization
problem related to mesh movement (that is, move nodes retaining
element connectivities). This problem uses a regularized functional,
wich introduces a global degree of freedom coupled with all others
dofs. To avoid assembling a sparse parallel AIJ matrix with a dense
column and row, we endup needing to solve two linear systems with the
same matrix for actually solving the Hessian of the regularized
functional.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
