leaks in multiple calls for preallocating AIJ matrices
Lisandro Dalcin
dalcinl at gmail.com
Tue Oct 23 14:16:15 CDT 2007
Looking at the actual code, it seems there is not need to actually
reallocate space, the same space can be reutilized. Do you think I'm
missing something?
And please, tell me: should I fix this in release-2.3.3? I believe
this will not impact previous user code in any way.
On 10/23/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Lisandro,
> I agree we should support multiple calls (or at worst generate an
> error on the second call). Presumably the specific
> MatXXXYYYSetPreallocation() routines would simply free up their
> current points and then (as it does now) allocate the appropriate new
> space. Feel free to add this.
> Barry
> On Mon, 22 Oct 2007, Lisandro Dalcin wrote:
> > Currently, making sucessive calls for preallocating AIJ matrices seem
> > to originate memory leaks.
> > How should this be corrected? I would prefer that this is a valid
> > operation, and fix appropriate routines to deallocate/reuse previous
> > memory, and set the new user-specified preallocation data.
> > Other point: should this fix go to release-2.3.3?
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
