PETSc-FUN3D Code
Satish Balay
balay at mcs.anl.gov
Mon Oct 22 14:27:06 CDT 2007
On Mon, 22 Oct 2007, Lisandro Dalcin wrote:
> Sathis, I have not much experience with fortran, but... if you take a
> look for example at
> http://www.mpi-forum.org/docs/mpi-20-html/node54.htm
> you will see
> MPI_ALLOC_MEM(SIZE, INFO, BASEPTR, IERROR)
> INTEGER INFO, IERROR
> INTEGER(KIND=MPI_ADDRESS_KIND) SIZE, BASEPTR
> So what the meaning of INTEGER(KIND=MPI_ADDRESS_KIND) is supposed to be??
If you check mpich2-1.0.5p4/src/binding/f77/type_extentf.c
#include "fproto.h"
FORT_DLL_SPEC void FORT_CALL mpi_type_extent_ ( MPI_Fint *v1, MPI_Fint * v2, MPI_Fint *ierr ){
MPI_Aint l2;
*ierr = MPI_Type_extent( (MPI_Datatype)(*v1), &l2 );
*v2 = (MPI_Fint)(l2);
MPI_Aint [on the c side] is used ambiguously as either
INTEGER(KIND=MPI_ADDRESS_KIND) for MPI_ALLOC_MEM or 'INTEGER' for
MPI_Type_extent.
Satish
