PETSc-FUN3D Code
Satish Balay
balay at mcs.anl.gov
Sat Oct 20 19:48:26 CDT 2007
Matt,
The primary problem here is:
we have size_t in prototypes - for eg:
PetscErrorCode PetscMemzero(void *a,size_t n);
So, when this routine is called from fortran - what datatype should
user-fortran-code use? Currently there is no equivalent for size_t.
[integer and size_t don't match on 64bit machines]
My proposal is to have PetscSizeT [atleast on the fortran side - that
is set properly - simlar to PetscFortranAddr].
And we normally have types match on both fortran & c - so should we
use it for C-side aswell?
PetscErrorCode PetscMemzero(void *a,PetscSizeT n);
BTW: This requires configure to set PETSC_SIZEOF_SIZE_T. [I've added
in this check]. But as you say - if size_t is not in system include
files - configure typedefs it. But I'm not sure if PETSC_SIZEOF_SIZE_T
test will compile in this case. [typdefs set by configure don't appear
to be used in checkSizeof() test.
Satish
On Sat, 20 Oct 2007, Matthew Knepley wrote:
> I actually like the autoconf solution. If the type is not found (size_t)
> then just typedef it as something.
> Matt
> On 10/20/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Satish,
> > I don't know; there are pros and cons to the two
> > approaches.
> > Why not PetscSize_T? I admit both look stupid, but the
> > _ at least matches the standard C style.
> > Any comments from the community?
> > Barry
> > I would like to keep size_t as the argument
> > On Sat, 20 Oct 2007, Satish Balay wrote:
> > > On Fri, 19 Oct 2007, Dinesh Kaushik wrote:
> > > > > > Perhaps need a PetscSizeT or some new datatype for this purpose that
> > > > > > gets set correct for both C & fortran side..
> > > Barry,
> > > Is it ok to do this change? The prototypes of the following functions
> > > will need to be changed to use PetscSizeT instead of size_t;
> > > [alternative is to use size_t on the C side - but PetscSizeT on the
> > > fortran side - but this is inconsistant]
> > > thanks,
> > > Satish
> > > PetscBagCreate
> > > PetscFileRetrieve
> > > PetscGetArchType
> > > PetscGetDate
> > > PetscGetDisplay
> > > PetscGetFullPath
> > > PetscGetHomeDirectory
> > > PetscGetHostName
> > > PetscGetProgramName
> > > PetscGetRelativePath
> > > PetscGetTmp
> > > PetscGetUserName
> > > PetscGetWorkingDirectory
> > > PetscLs
> > > PetscMalloc
> > > PetscMalloc2
> > > PetscMalloc3
> > > PetscMalloc4
> > > PetscMalloc5
> > > PetscMalloc6
> > > PetscMalloc7
> > > PetscMemcmp
> > > PetscMemcpy
> > > PetscMemmove
> > > PetscMemzero
> > > PetscOptionsGetenv
> > > PetscOptionsGetString
> > > PetscOptionsString
> > > PetscSetMalloc
> > > PetscSNPrintf
> > > PetscStrlen
> > > PetscStrncat
> > > PetscStrncmp
> > > PetscStrncpy
> > > PetscStrreplace
> > > PetscSynchronizedFGets
> > > PetscVSNPrintf
