PETSc-FUN3D Code
Sat Oct 20 17:00:58 CDT 2007
I actually like the autoconf solution. If the type is not found (size_t)
then just typedef it as something.
   Matt
On 10/20/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Satish,
>    I don't know; there are pros and cons to the two
> approaches.
>    Why not PetscSize_T? I admit both look stupid, but the
> _ at least matches the standard C style.
>   Any comments from the community?
>   Barry
>     I would like to keep size_t as the argument
> On Sat, 20 Oct 2007, Satish Balay wrote:
> > On Fri, 19 Oct 2007, Dinesh Kaushik wrote:
> > > > > Perhaps need a PetscSizeT or some new datatype for this purpose that
> > > > > gets set correct for both C & fortran side..
> > Barry,
> > Is it ok to do this change? The prototypes of the following functions
> > will need to be changed to use PetscSizeT instead of size_t;
> > [alternative is to use size_t on the C side - but PetscSizeT on the
> > fortran side - but this is inconsistant]
> > thanks,
> > Satish
> > PetscBagCreate
> > PetscFileRetrieve
> > PetscGetArchType
> > PetscGetDate
> > PetscGetDisplay
> > PetscGetFullPath
> > PetscGetHomeDirectory
> > PetscGetHostName
> > PetscGetProgramName
> > PetscGetRelativePath
> > PetscGetTmp
> > PetscGetUserName
> > PetscGetWorkingDirectory
> > PetscLs
> > PetscMalloc
> > PetscMalloc2
> > PetscMalloc3
> > PetscMalloc4
> > PetscMalloc5
> > PetscMalloc6
> > PetscMalloc7
> > PetscMemcmp
> > PetscMemcpy
> > PetscMemmove
> > PetscMemzero
> > PetscOptionsGetenv
> > PetscOptionsGetString
> > PetscOptionsString
> > PetscSetMalloc
> > PetscSNPrintf
> > PetscStrlen
> > PetscStrncat
> > PetscStrncmp
> > PetscStrncpy
> > PetscStrreplace
> > PetscSynchronizedFGets
> > PetscVSNPrintf
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
