finished changes for solving strict aliasing issue
Lisandro Dalcin
dalcinl at gmail.com
Tue Oct 2 13:03:39 CDT 2007
Not sure if any of you had the time to look at the small example I sended
to show the strict aliasing issue.
Anyway, I finished the changes needed to solve this issue, all C and
Fortran examples pass. If -Wno-strict-aliasing is removed, GCC will
still complain in many parts, but now we are sure that it will not
generate bad code when using PetscObject and derived structures. BTW,
I commented out all thos XXX_Publish() routines. Is this feature used
in any way? perhaps some external code? If this still have to be
supported, perhaps I can change PetscHeaderCreate() to pass the
publish routine.
Could you create a petsc-dev clone in the hg server in order I can
push this for your to review?
PD: Many thanks to Stephan for his 'sed' tip. It was of great help for
this to be finished.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
