error checking macros with optimization
Barry Smith
bsmith at mcs.anl.gov
Fri Nov 23 09:59:28 CST 2007
Lisandro,
There are actually two separate concerns: optimized builds and
error checking.
--with-errorchecking and --with-debugging I would like to keep them
separate.
Currently --with-errorchecking has an on or off value and --with-
debugging has an on or off value
If you are proposing an intermediate --with-errorchecking that simply
returns the
error codes that is fine with me.
--with-errorchecking=<on,intermediate,off>
I still want by default --with-debugging=0 to leave on the full error
checking. Reason:
most programmers are morons and develop code with optimization on
(why? because
they are dumb as stones and no matter how many times you tell them it
is a bad idea
they just ignore it, they prefer to spend hundreds of hours tracking
down bugs without
debug symbols then waste 1/1000 of a second on slower code while
developing.)
Barry
On Nov 23, 2007, at 9:25 AM, Lisandro Dalcin wrote:
> I would to propose some changes to error checking macros for
> optimized builds.
> 1.- SETERRQXXX: define them as
> #define SETERRQ[1|2|..](ierr,...) return ierr
> 2.- CHKERRQ: define them as
> #define CHKERRQ(ierr) if (ierr) return ierr
> For (1), it should be no performace impact. For (2), the extra check
> at almost every line of PETSc source code could impact performace, but
> any of you have a clear idea of how much?
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
