adding SNESSetLinearSolve()
Lisandro Dalcin dalcinl at gmail.com
Thu Nov 8 15:00:53 CST 2007
On 11/7/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
>        Go ahead add and add the features you'd like.
Well, I was thinking about all this. As I take very seriously all your
concerns, I've decided to implement anyway a full features 'python
shell' SNES. I was far more easier than I thought.
Once this is ready, I'll ask you to review a bit all the features, in
order to take a decision of what could be usefull and what is just
noise. Deciding this will be far easier with a sample working code.
In the proccess, I wanted to reuse the different default
implementations of line search for SNES, and I realized that they are
tied to SNES being of type SNESLS. I believe this coupling of
linesearch routines to SNESLS type can be avoided by taking advance of
the context argument passed in calls. Would this change be OK?
> On Nov 7, 2007, at 10:01 AM, Lisandro Dalcin wrote:
> > On 11/1/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >>> On Nov 1, 2007 9:24 AM, Lisandro Dalcin <dalcinl at gmail.com> > >>
> >>> For example, I would love to have SNESSetPresolve/SNESSetPostSolve
> >>>> and
> >>>> SNESSetPreStep/SNESSetPostStep, and perhaps a
> >>>> SNESSetPreLinearSolve/SNESSetPostLinearSolve. Of course, this make
> >>>> the
> >>>> API grow with features that are not frecuently needed.
> >>   I'd like to understand why they are ever needed and if they can be
> >> done
> >> with current constructs?
> > Barry, sorry for the delay, but I was really busy. I'll try to
> > clarify my needs.
> > * I'm using PETSc exclusively from Python. In such a dynamic language,
> > implementing complicated application setups is far easier than in
> > C/C++.
> > * Of course, Python is no efficient for low-level stuff. Do I actually
> > make use of a PETSc-based C++ application (PETSc-FEM) to assemble
> > vectors and matrices, manage fixations/boundary conditions and linear
> > constraints between dofs.
> > * Some application setups will need PETSc solvers (SNES/TS) to provide
> > a way to set user callback routines (or hooks). That's the reason I
> > talked about adding SNESSetPresolve/SNESSetPostSolve and
> > SNESSetPreStep/SNESSetPostStep. This way, PETSc can be adapted to the
> > application needs if required, and not the other way.
> > * Taking again SNES as an example: Why it provides SNESSetUpdate()???
> > It is not used in any other place in PETSc sources. I guess at some
> > point someone needed a user callback routine to be called just before
> > computing the Jacobian, so it was added. I'm currently using it to
> > compute/update auxiliar linear operators to be used in defining a
> > problem-based preconditioner for NS equations. Of course, I could do
> > this in computeJacobian() rutine, but then I would have to special
> > case the use of this preconditioner in order to compute the auxiliar
> > operator; in short my application has to adapt to PETSc.
> > * Taking TS as an exaple. Why it provides SetPreStep/SetPostStep???
> > They are also not even used in a TS example. I guess again that at
> > some point someone needed it. And then, I'm asking to have more of
> > that, and no less.
> > In the end, perhaps the better way for me to go is to implement SNES
> > and TS directly in Python and do what I want, it is not much hard and
> > there should not be performace issues at this level. But I would
> > really prefer to make SNES/TS more configurable (via setting general
> > pourpose user callback routines) in order to not duplicate code and
> > efforts.
> > So the real quention you have to answer is the following: Should I
> > continue fighting for making PETSc solver more 'user-configurable', or
> > should I direct my efforts in implemening all those features directly
> > in Python, where implementing truly polimorfic code is far, far easier
> > than in C?
> > In the near future, application written in C/C++/Fortran could take
> > advantage of petsc4py to implement custom 'shell' matrices, linear
> > solvers, preconditioners, nonlinear solvers and time steppers.
> > Something like
> > SNESCreate(comm,&snes)
> > SNESSetType(snes, "python")
> > SNESPythonCreate(snes, "package.module.MyNewtonSolver")
> > Woud'nt that be a really nice feature?
> > I'm not sure if all you consider Python (plus wrapped compiled code)
> > as a feasible way to drive large-scale simulations, but I really
> > believe it is. Furthermore, from the last three years I worked hard to
> > make it possible: now Python users can use mpi4py, petsc4py, slepc4py
> > and tao4py and manage applications with negligible overhead for medium
> > to large data transfers/ problems.
> > Lisandro Dalcín
> > Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> > Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> > Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> > PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> > Tel/Fax: +54-(0)342-451.1594
Lisandro Dalcín
