Windows version of PETSc
    Sumit Vaidya
    sumit_vaidya at persistent.co.in
    Wed Jun 13 07:21:35 CDT 2007
These are the machines supported by PETSc.
http://www.caspur.it/risorse/softappl/doc/petsc_docs/machines.html
>From this, I came to know that PETSc is already available for Windows with
32-bit processor.
Where can I get this software version of PETSc for windows?
Waiting for your reply,
Sumit
DISCLAIMER
This e-mail may contain privileged and confidential information which is the property of Persistent Systems Pvt. Ltd. It is intended only for the use of the individual or entity to which it is addressed. If you are not the intended recipient, you are not authorized to read, retain, copy, print, distribute or use this message. If you have received this communication in error, please notify the sender and delete all copies of this message. Persistent Systems Pvt. Ltd. does not accept any liability for virus infected mails.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20070613/d22413d7/attachment.html>
