PETSc sparsity
    Toby Young
    tyoung at ippt.gov.pl
    Fri Jun 15 13:54:51 CDT 2007
> If I understand you correctly, a trick we use for this is to use
> MatGetRow to get the sparcity pattern of each row (where you are
> applying BCs)
Neat trick. MatGetRow will give me the row of the matrix, so would then
need a little loop to examine the elements and proceed as you suggested;
am I right?
I guess there is no way to directly access the sparsity pattern then?
Thanks for the suggestion.
Best,
	Toby
Toby D. Young (Adiunkt)
Department of Computational Science
Institute of Fundamental Technological Research
Polish Academy of Science
Room 206, ul. Swietokrzyska 21
00-049 Warszawa, POLAND
