more comments about new build system
Mon Jun 11 20:56:27 CDT 2007
  Lisandro,
    Good point. etc was also suggested. Adding the petsc is
kind of ugly with the non-installed version, for example
petsc-dev/$PETSC_ARCH/shared/petsc/petscrules
instead of
petsc-dev/$PETSC_ARCH/shared/petscrules
  These things are still up in the air and will be adjusted
as good ideas come in.
   Barry
On Mon, 11 Jun 2007, Lisandro Dalcin wrote:
> If one of the goals of the new build system is to be more symmetric
> with the GNU model, in order to make life easier for packagers, so I
> think the '$PETSC_PREFIX/conf' location should be renamed, perhaps to
> '$PETSC_PREFIX/share/petsc'. I believe 'conf' is not a 'standard'
> location.
