changes to PETSc-dev bmake system and library locations
Lisandro Dalcin dalcinl at gmail.com
Mon Jun 11 10:09:40 CDT 2007
On 6/11/07, Satish Balay <balay at mcs.anl.gov> wrote:
> On Mon, 11 Jun 2007, Lisandro Dalcin wrote:
> There is nothing sepcial about having all installs inside a single
> PETSC_DIR.
> in the prefix model - the user specifies prefix just like any other
> package. For eg:
> --prefix=/usr/local --download-mpich
> This should install both the packages [PETSc & MPI] in
> /usr/local/[bin,include,lib]
I see the benefits now, I will try to update my build system for
petsc4py and see what happens...
Can you please tell me what would be now the correct way to
differentiate a 'build' mode and an 'install' mode? Just using
directory structure?
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
