changes to PETSc-dev bmake system and library locations
Matthew Knepley
knepley at gmail.com
Mon Jun 11 09:05:02 CDT 2007
Maybe you have an old BuildSystem?
Matt
On 6/11/07, Todd Munson <tmunson at mcs.anl.gov> wrote:
> I just downloaded the new updates and tried configuring the development
> version and get the following python errors...It may be a problem on my
> side. I'll try with a new clone of the repository...
> akita % ./config/configure.py --with-c++
> Configuring PETSc to compile on your system
> UNABLE to FIND MODULE for config/configure.py
> No module named Fiat
> File "./config/configure.py", line 175, in petsc_configure
> framework =
> config.framework.Framework(sys.argv[1:]+['--configModules=PETSc.Configure','--optionsModule=PETSc.compilerOptions'],
> loadArgDB = 0)
> File
> "/sandbox/tmunson/projects/petsc-dev/python/BuildSystem/config/framework.py",
> line 91, in __init__
> self.createChildren()
> File
> line 317, in createChildren
> self.getChild(moduleName)
> File
> line 302, in getChild
> config.setupDependencies(self)
> File "/sandbox/tmunson/projects/petsc-dev/python/PETSc/Configure.py",
> line 44, in setupDependencies
> utilityObj =
> self.framework.require('PETSc.'+d+'.'+utilityName, self)
> File
> line 322, in require
> config = self.getChild(moduleName, keywordArgs)
> File
> File "/sandbox/tmunson/projects/petsc-dev/python/PETSc/packages/FFC.py",
> line 11, in setupDependencies
> self.fiat = self.framework.require('config.packages.Fiat', self)
> File
> File
> line 275, in getChild
> type = __import__(moduleName, globals(), locals(),
> ['Configure']).Configureakita %
> Todd Munson (630) 252-4279 office
> Argonne National Laboratory (630) 252-5986 fax
> 9700 S. Cass Ave. tmunson at mcs.anl.gov
> Argonne, IL 60439 http://www.mcs.anl.gov/~tmunson
> On Sun, 10 Jun 2007, Barry Smith wrote:
> > On Sun, 10 Jun 2007, Matthew Knepley wrote:
> > > This is very vague concerning the structure of exernalpackages. I cannot tell
> > > where libraries are supposed to end up, and how/when/why they might be moved.
> > They end up in
> > $PETSC_ARCH/lib (same place as PETSc libraries, without a make install) and
> > prefix/lib (with a make install)
> > > It seems that the directory information coming from PETSc/package.py
> > > has also changed.
> > Yes. package.py had a /lib hardwired to the end of the install directory
> > returned by the particular package. Now the particular packages set the
> > entire path where the library goes (that is a /lib is not automatically
> > appended).
> > Barry
> > > Matt
> > > On 6/8/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > > PETSc-dev users,
> > > > After picking Satish's brain, I have made a set of changes to
> > > > petsc-dev related to compiling and linking programs.
> > > > Goal: Support the GNU; config/configure.py; make; make install model
> > > > including all external packages PETSc builds for you. After "make install"
> > > > PETSC_ARCH should not be needed.
> > > > Constraints:
> > > > * Allow skipping the "make install" step and yet having everything
> > > > fully functional even with shared and dynamic libraries
> > > > * Allow multiple builds in the non-"make install" approach which you can
> > > > switch between by changing PETSC_ARCH
> > > > * Not require any file links
> > > > * A system that does not mix generated files and non-generated in the same
> > > > directory in $PETSC_DIR
> > > > * A system no more complicated then the previous version.
> > > > Solution:
> > > > In place, before "make install"
> > > > petsc-dev/include same as now
> > > > /bin same as now
> > > > /conf basically the same as bmake/common was
> > > > $PETSC_ARCH/include generated includes: petscconf.h
> > > > petscfix.h ..
> > > > lib generated libraries
> > > > bin generated programs
> > > > conf basically the same as bmake/$PETSC_ARCH/
> > > > except not the include files
> > > > prefix/include all includes
> > > > /bin all programs, including mpiexec, mpicc if
> > > > generated
> > > > /conf the stuff previous in bmake/common and
> > > > bmake/$PETSC_ARCH
> > > > /lib the libraries, including from external
> > > > packages
> > > > The whole trick is that in the PETSc bmake files (now conf files :-)) the
> > > > $PETSC_ARCH/
> > > > disappears in the "make install" version.
> > > > I have fixed the external packages MPI.py, BlasLapack.py and Chaco.py but
> > > > the others
> > > > need to be modified to stick their libraries and includes in the new correct
> > > > place.
> > > > The only change you should need to your makefiles is to replace
> > > > include ${PETSC_DIR}/bmake/common/base with
> > > > include ${PETSC_DIR}/conf/base
> > > > Bug reports to petsc-maint at mcs.anl.gov questions to petsc-dev at mcs.anl.gov
> > > > Barry
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
