[PETSC #16447] Multiple definitions of assorted symbols in src/sys/objects/ (fwd)
Barry Smith
bsmith at mcs.anl.gov
Thu Jul 12 22:18:03 CDT 2007
---------- Forwarded message ----------
Date: Thu, 12 Jul 2007 22:11:26 -0500
Reply-To: brune at uchicago.edu
To: petsc-maint at mcs.anl.gov
Cc: petsc-maint at mcs.anl.gov
Subject: [PETSC #16447] Multiple definitions of assorted symbols in
src/sys/objects/
Upon making PETSc I get linking errors when making the shared libraries.
My configure line is:
--with-dynamic --download-fiat=1 --download-mpich --with-sieve
--download-boost --with-clanguage=c++ --download-chaco --download-triangle
--download-tetgen --with-shared=0 --download-generator=1 --download-parmetis
Here are the relevant parts of make_log:
making shared libraries in
/home/emppter/Packages/petsc-dev/linux-gnu-c-real-debug/lib
building libpetsc.so
pinit.o: In function `PetscCookieRegister(int*)':
/home/emppter/Packages/petsc-dev/src/sys/objects/pinit.c:48: multiple
definition of `PETSC_LISTEN_CHECK'
init.o:/home/emppter/Packages/petsc-dev/src/sys/objects/init.c:70: first
defined here
definition of `PETSC_LISTENFD'
defined here
definition of `PETSC_SOCKFD'
defined here
zope.o: In function `PetscOpenSocket(char*, int)':
/home/emppter/Packages/petsc-dev/src/sys/objects/zope.c:8: multiple
defined here
defined here
defined here
collect2: ld returned 1 exit status
make[2]: [shared_linux] Error 1 (ignored)
building libpetscvec.so
building libpetscmat.so
building libpetscdm.so
building libpetscksp.so
building libpetscsnes.so
building libpetscts.so
building libpetsccontrib.so
- Peter
