changes to petsc-dev directories
    Farshid Mossaiby
    mossaiby at yahoo.com
    Tue Dec 18 04:15:42 CST 2007
Hi everybody,
Is there a problem with the list-server or just
everybody is too busy?
--- Barry Smith <bsmith at mcs.anl.gov> wrote:
>     Very valid point.
>     Barry
> On Dec 14, 2007, at 7:37 PM, Dmitry Karpeev wrote:
> > If maint/ is going into bin/maint/, I think
> config/ should also go
> > to bin/config/
> > (I think someone already suggested it).  The
> reason is that these
> > are auxiliary scripts
> > used to configure and build PETSc.  Their output
> -- the actual PETSc
> > configuration --
> > goes into conf/ and ${PETSC_ARCH}/conf and
> everything makes sense.
> > Besides, there is no need to install bin/config/
> and violate one
> > standard or another,
> > since an installation implies a particular
> configuration, which is
> > already in
> > conf/ etc.
> > Dmitry.
> > On 12/14/07, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > Reforwarding e-mail blocked by majordomo [reason:
> ^config is special
> > command to majordomo]
> > Satish
> > ---------- Forwarded message ----------
> > From: Barry Smith <bsmith at mcs.anl.gov >
> > To: petsc-dev at mcs.anl.gov
> > Subject: changes to petsc-dev directories
> > Date: Sat, 8 Dec 2007 21:55:10 -0600
> >      I have moved python/PETSc to config/PETSc and
> python/
> > BuildSystem to
> >   config/BuildSystem
> >   in addition I have moved the maint directory to
> bin/maint and
> > removed
> >   conf/rules.basic.shared
> >   After your next hg pull do:
> >   mv python/BuildSystem config
> >   rm -rf python
> >     Any user makefiles and code should not need
> any changes
> >       Barry
      ____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.  http://tools.search.yahoo.com/newsearch/category.php?category=shopping
