changes to petsc-dev directories
    Dmitry Karpeev
    karpeev at mcs.anl.gov
    Fri Dec 14 19:37:38 CST 2007
If maint/ is going into bin/maint/, I think config/ should also go to
bin/config/
(I think someone already suggested it).  The reason is that these are
auxiliary scripts
used to configure and build PETSc.  Their output -- the actual PETSc
configuration --
goes into conf/ and ${PETSC_ARCH}/conf and everything makes sense.
Besides, there is no need to install bin/config/ and violate one standard or
another,
since an installation implies a particular configuration, which is already
in
conf/ etc.
Dmitry.
On 12/14/07, Satish Balay <balay at mcs.anl.gov> wrote:
> Reforwarding e-mail blocked by majordomo [reason: ^config is special
> command to majordomo]
> Satish
> ---------- Forwarded message ----------
> From: Barry Smith <bsmith at mcs.anl.gov>
> To: petsc-dev at mcs.anl.gov
> Subject: changes to petsc-dev directories
> Date: Sat, 8 Dec 2007 21:55:10 -0600
>      I have moved python/PETSc to config/PETSc and python/BuildSystem to
>   config/BuildSystem
>   in addition I have moved the maint directory to bin/maint and removed
>   conf/rules.basic.shared
>   After your next hg pull do:
>   mv python/BuildSystem config
>   rm -rf python
>     Any user makefiles and code should not need any changes
>       Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20071214/cbccbd5d/attachment.html>
