petsc-dev directory structure questions
Fri Dec 14 13:46:01 CST 2007
On Fri, 14 Dec 2007, Satish Balay wrote:
> On Fri, 14 Dec 2007, Barry Smith wrote:
> > On Dec 14, 2007, at 12:05 PM, Satish Balay wrote:
> > > On further thought, I'm ok with merging conf and config - provided
> > > 'config' [which would be the new merged name for conf]
> >   Why config instead of conf?
> I picked 'config' just so that './config/configure.py' user interface
> is preserved.
> > > would not have
> > > any of the old $PETSC_DIR/python stuff. [i,e if it goes somewere into
> > > $PETSC_DIR/src/foobar]
> >   Why should it go somewhere else; it manages all the configuration
> > so it should be with the configuration stuff.
> There is a difference between pythonmodules [i.e old PETSC_DIR/python]
> and python-usercode [i.e configure.py]. And I certainly don't like
> dumping all 3 [petscconf, configure.py & python-modules] in the same
> location.
> Ideally they should be in 3 different locations.  But I'm buying the
> argument that there is a weak relation between petscconf and
> configure.py so its not terrible to have these two together. [There is
> a stronger relation between pythonmodules & configure.py]. But having
> all 3 in config is just not right. I can't see a way to explain why
> that would be a consistant design. [and if we can put any thing
> anywhere - jut because its convinent - we could probably throw away
> lot more things].
> >   src traditional means code that gets compiled up and put in a
> > library or executable: the old PETSC_DIR/python stuff definitely
> > does not fit in that category.
> Not really - src is source for anything. For eg: we have
> src/docs/website src/docs/manual which are sources for other
> derivative stuff [aka manual.pdf, http://www.mcs.anl.gov/petsc]
> If we stick to your argument - then we'll have to find new places for
> this [i.e go back to PETSC_DIR/src where sources & generated docs were
                             ^^^^^^ sorry - I meant PETSC_DIR/doc
> dumped in the same location with too much confusion about website?]
> > > We currently have generated files anyway at
> > > PETSC_ARCH/conf/[configure.py,petscconf,petscrules], so I guess
> > > PETSC_DIR/config/[configure.py,linux-gnu.py,base,rules,..]  should be
> > > equivalent.
> >  Having PETSC_DIR/config/variables,rules but
> > PETSC_ARCH/conf/petscconf seems VERY wrong to me. Why is
> > one directory config and the other one conf?
> I guess I was implicitly indicating we should obsolete either 'conf'
> or 'config'. And I sugested using config.
> So PETSC_DIR/config & PETSC_ARCH/config would be the only new names.
> Satish
