remove python directory?
Satish Balay
balay at mcs.anl.gov
Fri Dec 14 09:54:25 CST 2007
Reforwarding e-mail blocked by majordomo [reason ^config is special
command to majordomo]
Satish
---------- Forwarded message ----------
To: petsc-dev at mcs.anl.gov
Subject: remove python directory?
Date: Fri, 23 Nov 2007 21:52:02 -0600
Can we move python/PETSc and python/BuildSystem to config/PETSc and
config/BuildSystem and
Reason: a directory should not be named after the language it uses,
PETSc and BuildSystem
are config stuff and the other stuff in python is no longer used.
Barry
