petsc-dev directory structure questions
    Barry Smith
    bsmith at mcs.anl.gov
    Sat Dec  8 22:13:24 CST 2007
    Currently petsc-dev has the subdirectories
      bin include src conf config ...
$PETSC_ARCH has the subdirectories
    bin include conf lib ...
conf has
    adic.init		adicmf.init		base			test
    adicmastercontrol	adicmfb.init		rules			variables
config has
    PETSc BuildSystem configure.py   +tons of sample configure.py
files for different systems
  I find that having both a conf and a config directory is confusing
and unneeded and propose:
1) merging the config and conf directory
2) putting the ons of sample configure.py files for different systems
into a subdirectory called samples
Questions:
1) Does this make sense?
2) What should the directory be called? conf or config? Are there any
standards that dictate/suggest
     one over the other? If we use config then I would like to change
the $PETSC_ARCH/conf directory
     to match it, but would that violate some standard? I'm inclined
to go with conf even though that breaks
     our long standing config/configure.py script to become conf/
configure.py
3) This is perhaps also a good time to reopen the question of PETSc
"installs": currently they go into
     (system independent) prefix/bin prefix/include prefix/conf and
the system dependent prefix/$PETSC_ARCH/conf
     prefix/$PETSC_ARCH/include prefix/$PETSC_ARCH/lib If one selects
a PETSC_ARCH of "" then
     everything ends up in prefix/bin prefix/include prefix/conf
prefix/lib.
    The reason for this design is so that the same makefiles with
includes based on PETSC_DIR and
    PETSC_ARCH will work in all three cases: no install of PETSc,
install with PETSC_ARCH and install with
    PETSC_ARCH ""
    I know we will never get full agreement on everything, but what
are the concerns with this layout?
    Thanks
      Barry
Remember if I don't get comments I may do some crazy thing :-(
