warn message in log summary
    Lisandro Dalcin
    dalcinl at gmail.com
    Fri Dec  7 16:32:15 CST 2007
On 12/7/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > I'm on Matt's side. Have you ever considered C++ for implementing
> > PETSc internals?
>    Python?
Not sure if that was a joke, but in any case, definitely no. For PETSc
internals, and for many reasons,  a C++ code using simple features
(trying avoiding templates, rtti, and all data) like exception
handling and polymorphism would simplify a lot the implementation of
derived object types (the compiler fills for you the table of method
pointers) and error management (the compiler thow exceptions, you do
not need to check error codes at almost every line). If C++ exceptions
ever cause a loss of performance, the selected parts of all the code
doing very heavy number crunching can be implemented in C/Fortran.
If PETSc internal were implemented in C++, then we would be able to
take advantage of some tools like SWIG, straightforwardly enabling
cross-language polymorphism, for implementing new type objects in pure
python code, or even inherit for some type and specialize some
methods. But this would be for the long, long future.
> On Dec 7, 2007, at 7:28 AM, Lisandro Dalcin wrote:
> > On 12/7/07, Matthew Knepley <knepley at gmail.com> wrote:
> >> On Dec 6, 2007 9:00 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >>>   I am very nervous about mixing a catastrophic error handling
> >>> system
> >>> WITH an exception system. I'd like to go back to the model:
> >>> "once seterrq() is called ANYWHERE there is no possibility of
> >>> continuing the program.
> >> I guess I have the opposite opinion. I think it is inevitable that
> >> PETSc
> >> is rewritten at some point in the future. At that point, we would
> >> replace
> >> the current, imperfect exception system with a better one. This way
> >> we
> >> can preserve a good design. If we go the other way, all that code
> >> will
> >> have to be rethought instead of just rewritten.
> > PETSc internals?
> > Lisandro Dalcín
> > Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> > Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> > Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> > PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> > Tel/Fax: +54-(0)342-451.1594
Lisandro Dalcín
