warn message in log summary
Lisandro Dalcin
dalcinl at gmail.com
Fri Dec 7 07:28:50 CST 2007
On 12/7/07, Matthew Knepley <knepley at gmail.com> wrote:
> On Dec 6, 2007 9:00 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > I am very nervous about mixing a catastrophic error handling system
> > WITH an exception system. I'd like to go back to the model:
> > "once seterrq() is called ANYWHERE there is no possibility of
> > continuing the program.
> I guess I have the opposite opinion. I think it is inevitable that PETSc
> is rewritten at some point in the future. At that point, we would replace
> the current, imperfect exception system with a better one. This way we
> can preserve a good design. If we go the other way, all that code will
> have to be rethought instead of just rewritten.
I'm on Matt's side. Have you ever considered C++ for implementing
PETSc internals?
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
