GMRES/FGMRES and KSP_NORM_NO
Barry Smith
bsmith at mcs.anl.gov
Wed Aug 29 15:41:02 CDT 2007
Good argument. Make the change requiring setting both.
Barry
On Wed, 29 Aug 2007, Lisandro Dalcin wrote:
> > > Now, other issue, regarding this adition. Currently, passing
> > > '-ksp_norm_type NO' ALSO set KSPSkipConverged. Should I remove that?
> > No, I think it should remain the same.
> OK, but then there is something that is a bit confusing IMHO,
> 1- if you use command line your automatically get KSP_NORM_NO + KSPSkipConverged
> 1- if you call KSPSetNormType(ksp, KSP_NORM_NO), you do not get
> SkipConverged. Perhaps KSPSetNormType() should be in charge of setting
> SkipConverged()? Or is this too much second-guessing the user?
