rename ISLocalToGlobalMapping?
Lisandro Dalcin
dalcinl at gmail.com
Tue Aug 28 08:52:22 CDT 2007
And then {Vec|Mat}SetValuesLocal (after renaming, perhaps to
XXXSetValuesMapped) could be implemented in terms of a general
mapping. This seems really nice. What do you think?
PetscMapping seems a good unification for AO and ISLGM. It should be
in the Vec package, right? And it should be a very general object, as
current implementations of AO and ISLGM are rather different regarding
structure and scalability.
On 8/27/07, Matthew Knepley <knepley at gmail.com> wrote:
> It would probably be better. AOMapping and ISLocaltoGlobal have
> about the same interface.
> Matt
> On 8/27/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Should AO and ISLocalToGlobalMapping be merged into
> > a PetscMapping class?
> > struct _p_ISLocalToGlobalMapping{
> > PETSCHEADER(int);
> > PetscInt n; /* number of local indices */
> > PetscInt *indices; /* global index of each local index */
> > PetscInt globalstart; /* first global referenced in indices */
> > PetscInt globalend; /* last + 1 global referenced in indices */
> > PetscInt *globals; /* local index for each global index between
> > start and end */
> > typedef struct {
> > PetscInt N;
> > PetscInt *app; /* app[i] is the partner for petsc[appPerm[i]] */
> > PetscInt *appPerm;
> > PetscInt *petsc; /* petsc[j] is the partner for app[petscPerm[j]] */
> > PetscInt *petscPerm;
> > } AO_Mapping;
> > typedef struct {
> > PetscInt N;
> > PetscInt *app,*petsc; /* app[i] is the partner for the ith PETSc slot */
> > /* petsc[j] is the partner for the jth app slot */
> > } AO_Basic;
> > Barry
> > > > Lisandro,
> > > > Sounds fine to me. ISLocalToGlobalMapping -> LGMapping
> > > If we are getting picky, I like long names, but I would get rid of IS
> > > since it seems
> > > more like implementation to me.
> > > > BUT, AO is called AO, not AOMapping? Shouldn't it be AOMapping?
> > > > (then the AO_Mapping needs to be changed, why it is called
> > > > Mapping, Matt?, I do not know).
> > > The default AO implementation has the semantic guarantee that it is a
> > > permutation.
> > > The Mapping implementation allows subsets of the index space.
> > > Matt
> > > > Barry
> > > > On Thu, 16 Aug 2007, Lisandro Dalcin wrote:
> > > > > Did you never thinnk about the possibility of renaming
> > > > > ISLocalToGlobalMapping to something shorter? IMOH it is painfuly long
> > > > > name.
> > > > > In petsc4py, I call this LGMapping, because ISLocalToGlobalMapping, in
> > > > > my view, is not an IS, and its usage is similar to AOMapping.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
