rename ISLocalToGlobalMapping?
Mon Aug 27 21:28:16 CDT 2007
    Should AO and ISLocalToGlobalMapping be merged into
a PetscMapping class?
struct _p_ISLocalToGlobalMapping{
  PETSCHEADER(int);
  PetscInt n;                  /* number of local indices */
  PetscInt *indices;           /* global index of each local index */
  PetscInt globalstart;        /* first global referenced in indices */
  PetscInt globalend;          /* last + 1 global referenced in indices */
  PetscInt *globals;           /* local index for each global index between
start and end */
typedef struct {
  PetscInt N;
  PetscInt *app;       /* app[i] is the partner for petsc[appPerm[i]] */
  PetscInt *appPerm;
  PetscInt *petsc;     /* petsc[j] is the partner for app[petscPerm[j]] */
  PetscInt *petscPerm;
} AO_Mapping;
typedef struct {
  PetscInt N;
  PetscInt *app,*petsc;  /* app[i] is the partner for the ith PETSc slot */
                         /* petsc[j] is the partner for the jth app slot */
} AO_Basic;
  Barry
On Mon, 27 Aug 2007, Matthew Knepley wrote:
> On 8/27/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   Lisandro,
> >     Sounds fine to me. ISLocalToGlobalMapping -> LGMapping
> If we are getting picky, I like long names, but I would get rid of IS
> since it seems
> more like implementation to me.
> >     BUT, AO is called AO, not AOMapping? Shouldn't it be AOMapping?
> >    (then the AO_Mapping needs to be changed, why it is called
> >     Mapping, Matt?, I do not know).
> The default AO implementation has the semantic guarantee that it is a
> permutation.
> The Mapping implementation allows subsets of the index space.
>   Matt
> >    Barry
> > On Thu, 16 Aug 2007, Lisandro Dalcin wrote:
> > > Did you never thinnk about the possibility of renaming
> > > ISLocalToGlobalMapping to something shorter? IMOH it is painfuly long
> > > name.
> > > In petsc4py, I call this LGMapping, because ISLocalToGlobalMapping, in
> > > my view, is not an IS, and its usage is similar to AOMapping.
