rename ISLocalToGlobalMapping?
Barry Smith
bsmith at mcs.anl.gov
Mon Aug 27 21:06:14 CDT 2007
Lisandro,
Sounds fine to me. ISLocalToGlobalMapping -> LGMapping
BUT, AO is called AO, not AOMapping? Shouldn't it be AOMapping?
(then the AO_Mapping needs to be changed, why it is called
Mapping, Matt?, I do not know).
Barry
On Thu, 16 Aug 2007, Lisandro Dalcin wrote:
> Did you never thinnk about the possibility of renaming
> ISLocalToGlobalMapping to something shorter? IMOH it is painfuly long
> name.
> In petsc4py, I call this LGMapping, because ISLocalToGlobalMapping, in
> my view, is not an IS, and its usage is similar to AOMapping.
