multiple definition of `PETSC_ZOPEFD'
Brian Cordonnier bcordonn at uchicago.edu
Fri Aug 10 13:09:14 CDT 2007
I ran configure with that option, and got a configuration crash.  Now,
when I run it even without that option I get a crash too.  What should I do?
Brian
Satish Balay wrote:
> Brian,
> Most of these issues have come up with shared libraries.
> You can make this your default config by rerunning configure with the
> additional option '--with-shared=1'
> Satish
> On Fri, 10 Aug 2007, Brian Cordonnier wrote:
>> I think I fixed it, but I could not reproduce your error, let me know if you
>> still get it.
>> Brian
>> Lisandro Dalcin wrote:
>>> Can someone decide where to define PETSC_ZOPEFD? I would change it,
>>> but not shure what is better.
>>> BTW, can someone point me a link or something to all this new Zope stuff?
>>> making shared libraries in
>>> /u/dalcinl/Devel/PETSc/petsc-dev-gmresr/linux-gnu/lib
>>> building libpetsc.so
>>> mprint.o: In function `PetscFormatConvert':
>>> /u/dalcinl/Devel/PETSc/petsc-dev-gmresr/src/sys/fileio/mprint.c:30:
>>> init.o:/u/dalcinl/Devel/PETSc/petsc-dev-gmresr/src/sys/objects/init.c:70:
>>> first defined here
>>> Regards,
