Using complex from C code
    Satish Balay
    balay at mcs.anl.gov
    Fri Jun 30 15:30:43 CDT 2006
Added to petsc-dev now.
Satish
On Fri, 30 Jun 2006, Barry Smith wrote:
>    Mathieu,
>     Cool, thanks.
>    Satish,
>     Could you please apply the diff to petsc-dev now and then push
> so any future changes anyone makes will be combatiable with the new
> code.
>     Thanks
>      Barry
> On Fri, 30 Jun 2006, Mathieu Taillefumier wrote:
> > Good morning everybody,
> > I finished to modify the code of the library in order to compile the
> > complex version with a C compiler. A few numbers of files have been
> > modified. This modifications include a modification of the file
> > language.py where I put in comment two lines forcing to compile the
> > library with a c++ compiler. Since I don't really know python, I just
> > put them as a comment, but i think it is better to put a message
> > indicating that compiling the complex version of Petsc needs a C90
> > compliant compiler (gcc 3.4 and after work, it works also with icc) and
> > is experimental. Actually I am working with this modifications and it
> > seems to work like a charm (I had no problem with it).
> > I still need some time to convert the example programs which do not
> > compile but it will be done soon.
> > Note for all of us :
> >    Don't use the name I as a variable anymore. It is a reserved word of
> > the language.
> >    For most of us, the modifications must be transparent.
> > Regards
> > Mathieu
