no file comments for hg
    Yaron Kretchmer
    yaronkretchmer at gmail.com
    Tue Jul 25 23:15:15 CDT 2006
QT4 has a QT3 "compatability layer". there's even a qt3to4 tool which looks
at the source code and mutates all the QT3 calls to QT4 calls. It works
quite well
Yaron
On 7/25/06, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Satish,
>    Your proposed solution is ridiculously cumbersome; no sane person
> would put up with that nonsense.
>   If the authors of the ct would get their heads out of their
> asses and update it to Qt4 (which is like, what, a year old) instead
> of the outdated Qt3 maybe people who use updated software could use it.
>    Barry
> On Tue, 25 Jul 2006, Satish Balay wrote:
> >>> Yes - not having file comments makes it more difficult to go back in
> >>> file history.
> >>> But one way to look at it is - for some of these senarios - it meanas
> >>> multiple changesets should be created [with the correct grouping of
> >>> changes] instead of the atempted single changeset.
> >>    Yes, the problem with this is that there is no decent way of
> >> making multiple change-sets.
> > - quit emacs without typing in any comments  [so no commit is done]
> > - 'hg status' to get the list of modified files
> > - hg commit file1 file2 [ to make the appropriate changeset]
> > I use 'hg ct' though..
> >> If I could just edit out the files
> >> I did not want when doing the comment for a commit it would make
> >> life a MILLION times better (could that be added?).
> > I'll check on this on the mercurial list..
> > Satish
> >>    Barry
> >>> And perhaps some comments can actually go into the code.
> >>> Satish
> >>>>   Not having file by file comments for changesets is
> >>>> starting to annoy me.
> >>>>    Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20060725/8e1bda9d/attachment.html>
