[PETSC #13286] Make pcimpl.h a public API
Barry Smith petsc-maint at mcs.anl.gov
Thu Oct 13 09:18:27 CDT 2005
   I have finally made this change. pcimpl.h has been moved
from src/ksp/pc/pcimpl.h to include/private/pcimpl.h (thus
"make install" will preserve it). Anyone using pcimpl.h with
petsc-dev will need to make the change in their source code.
   Barry
On Mon, 4 Jul 2005, Johan Jansson wrote:
> Hi!
> We've implemented a PetSc preconditioner in DOLFIN, but it seems the
> preconditioner implementation API (pcimpl.h) isn't a public API
> (i.e. user code cannot see it). We've solved this by copying pcimpl.h
> into DOLFIN, but this is not a good solution. Could you consider
> making the preconditioner implementation API public?
> The reason the preconditioner is implemented in DOLFIN and not in
> PetSc is because the preconditioner depends on DOLFIN. The idea is to
> solve a nonlinear system in a time-stepping method for ODEs by
> Newton's method with a Krylov solver preconditioned with a fixed-point
> solver. The fixed-point solver is part of DOLFIN. There are likely
> other such applications of externally implemented preconditioners.
> Thank you,
>   Johan
