MatStash() use linked list of chunks
Matthew Knepley
knepley at mcs.anl.gov
Tue Dec 13 16:43:26 CST 2005
Richard Katz <katz at ldeo.columbia.edu> writes:
> Matt,
> When we get together to work on the semi-Lag stuff we should make this interface clear.
Okay. I will try at something tomorrow as a rough cut.
Matt
> Rich
> On Dec 13, 2005, at 4:38 PM, Barry Smith wrote:
>> Rich,
>> Outline what you use/need in terms of an interface for that case.
>> We can gather the cases to see what commonality comes out.
>> Barry
>> BTW: I was joking about the "stinking ..."
>> On Tue, 13 Dec 2005, Richard Katz wrote:
>>> A PETSc linked-list object might also be useful in implementations of
>>> characteristics-based advection schemes such as semi-Lagrangian advection.
>>> Perhaps you could give it some sorting methods too?
>>> but then again, this is just "stinking computer science"...
>>> Rich
>>> On Dec 13, 2005, at 1:22 PM, Richard Tran Mills wrote:
>>>> I agree with Matt's take on this. Having a linked-list to be used
>>>> throughout PETSc as appropriate could be quite useful.
>>>> I am a fan of doubly-linked list implementations like the one described at:
>>>> http://www.cs.utk.edu/~plank/plank/classes/cs360/360/notes/Dllists/
>>>> (This is part of Jim Plank's libFDR library, which also includes a nice
>>>> red-black tree implementation.)
>>>> Jim's Dllist stuff stores "Jvals" which are a union of all intrinsic C data
>>>> types -- that way you can stash whatever you want in a node of the list. I
>>>> don't know if an approach that general is needed in PETSc or not, but the
>>>> flexibility is nice.
>>>> --Richard
>>>> Matthew Knepley wrote:
>>>>> If we are really going to do this, shouldn't we approach it as a
>>>>> data structures problem? We need a certain structure, which here appears
>>>>> to be "vector", or maybe "list". We make a general interface, and then
>>>>> code up some implementation, like a linked list. Then we can use this
>>>>> interface/impl other places in the code, like the LU part, rather than
>>>>> rely on our old cut&paste strategy.
>>>>> Matt
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec Guiness
