[petsc-announce] petsc-3.7.5.tar.gz now available
Sun Jan 1 10:55:56 CST 2017
Dear PETSc users,
The patch release petsc-3.7.5 is now available for download.
http://www.mcs.anl.gov/petsc/download/index.html
Some of the changes include:
 * SuperLU_DIST: update to verison 5.1.3 for bug fixes.
 * configure: improve MKL detection on OSX
 * MUMPS: update to version 5.0.2-p2 for bug fixes.
 * ctable: update to use double hashing - to fix performance issues
 * configure: allow using both release tarballs and git tarballs for petsc4py, superlu, superlu_dist etc.
 * SuperLU_DIST: set FactPattern = SamePattern_SameRowPerm as default when reuse matrix factor
 * SuperLU_DIST: Bugfix for repeated call of MatLUFactorNumeric_SuperLU_DIST()
 * TSRK: fix memory corruption
 * TS: allow unassembled mats in compute IJacobian.
 * MATMPIBAIJ: Bug fixes for MAT_USE_HASH_TABLE
 * DMLocalizeCoordinates: Use PETSC_COMM_SELF for local coordinate vector
 * pastix: update to version 5.2.3 - for some build fixes
 * PCSetUp_SVD():fix issue with using incorrect matrix for matrix size in parallel
 * PetscOptions: Make PetscOptionsSetValue/ClearValue symmetric with mixed-case
 * MatMUMPS: fix conversion from SeqAIJ to mumps upper triangular format in case of missing diagonal
 * MatSeqAIJ: fix improper use of diagonal wrt MatZeroRows_SeqAIJ() and MatZeroRowsColumns_SeqAIJ()
Satish
More information about the petsc-announce mailing list
