[petsc-announce] petsc-3.4.2.tar.gz now available
Satish Balay
balay at mcs.anl.gov
Tue Jul 2 10:11:59 CDT 2013
Dear PETSc users,
The patch release petsc-3.4.2 is now available for download.
http://www.mcs.anl.gov/petsc/download/index.html
Some of the changes include:
* plog: Fixed Fortran binding for PetscLogPrintDetailed()
* fixed src/dm/examples/tutorials/ex7.c to use replacement for PetscViewerBinaryMatlabOpen() also needed to fix bin/matlab/PetscBagRead.m for new location of bagimpl.h and put bagimpl.h into the appropriate public place
* badly formatted /*I "include" I*/, unused variables fixed that compile with MATLAB
* sundials: disable f77 properly
* exodus: cleanup build process [make.inc is unused & fix postInstall() to use the correct file]
* exodus: do 'make clean' between repeat builds
* mpicc: disable 'wrapper override check' when user provides --with-mpi-compilers=0
* Fortran: PCMGResidual_Default needs to handle double-underscore
* version: fix PETSC_VERSION_LT() to require PETSC_VERSION_RELEASE=1
* Escape quotes in paths in petscmachineinfo.h
* configure: handle paths with spaces in getExecutable(). Now the following works: '--with-mpiexec=/cygdrive/c/Program\ Files/MPICH2/bin/mpiexec -localonly',
* tgamma: icc on windows requires mathimf.h for tgamma. [but configure doesn't use any includes in tgamma test]
Satish
More information about the petsc-announce
