[Parvis-users] [EXTERNAL] Re: ParNCL build problems
Peterson, Kara J.
kjpeter at sandia.gov
Tue Nov 25 12:45:57 CST 2014
After looking at the make output it appears that there are undefined
references to Teuchos functions. Teuchos is a part of Trilinos that is a
backbone for many basic computations. If Trilinos is configured to build
Intrepid,Teuchos should build automatically because it is a necessary
dependency. Can you check the configure and make output for Trilinos?
Best,
Kara
On 11/25/14, 10:57 AM, "Krishna, Jayesh" <jayesh at mcs.anl.gov> wrote:
>Hi,
> Which version of Trilinos are you using?
> As we are debugging this issue can you try an older version of Trilinos,
>11.0.3 or 10.6.4, and see if it works for you?
>Regards,
>Jayesh
>________________________________________
>From: parvis-users-bounces at lists.mcs.anl.gov
>[parvis-users-bounces at lists.mcs.anl.gov] on behalf of Krishna, Jayesh
>[jayesh at mcs.anl.gov]
>Sent: Tuesday, November 25, 2014 8:59 AM
>To: Aditya Support
>Cc: parvis-users at lists.mcs.anl.gov
>Subject: Re: [Parvis-users] ParNCL build problems
>Hi,
> After a closer look at the make output, it looks like parncl was not
>built correctly. There are many undefined references to Intrepid
>functions. I will ping you soon with my findings.
>Regards,
>Jayesh
>From: Aditya Support [adityasupport at tropmet.res.in]
>Sent: Tuesday, November 25, 2014 6:53 AM
>To: Krishna, Jayesh
>Subject: Re: ParNCL build problems
>Hi Jayesh,
>Also find the below command output:
>iitmlogin3:/gpfs3/gpfs7/home/ibm/AMIT/PARNCL/PARNCL1/PARNCL/bin $ file
>parncl
>parncl: data
>'parncl' is a data file. Please let me know whether it is created
>correctly or not.
>Regards,
>Amit
>----- Original Message -----
>From: "Aditya Support" <adityasupport at tropmet.res.in>
>To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
>Sent: Tuesday, November 25, 2014 6:13:07 PM
>Hi Jayesh,
>Yes i am having permission to execute, you can check the below command
>examples:
>iitmlogin3:/gpfs3/gpfs7/home/ibm/AMIT/PARNCL/PARNCL1/PARNCL/bin $ ls -l
>parncl
>-rwxr-xr-x 1 ibm lsfadmin 71304088 Nov 24 16:10 parncl
>iitmlogin3:/gpfs3/gpfs7/home/ibm/AMIT/PARNCL/PARNCL1/PARNCL/bin $ ./parncl
>-bash: ./parncl: cannot execute binary file
>iitmlogin3:/gpfs3/gpfs7/home/ibm/AMIT/PARNCL/PARNCL1/PARNCL/bin $ id
>uid=502(ibm) gid=501(lsfadmin) groups=501(lsfadmin)
>Regards,
>Amit
>From: "Jayesh Krishna" <jayesh at mcs.anl.gov>
>To: "Aditya Support" <adityasupport at tropmet.res.in>
>Sent: Tuesday, November 25, 2014 6:10:08 PM
>Subject: RE: ParNCL build problems
>Hi,
> Do you have permissions to execute the binary file? Are you cross
>compiling your code?
> I would recommend that you contact your system administrator to solve
>this issue. Please let us know the results.
>Regards,
>Jayesh
>Sent: Monday, November 24, 2014 11:04 PM
>To: Krishna, Jayesh
>Hi Jayesh,
>Thanks for the reply!!!
>Please find the below directory listing of
>/gpfs3/gpfs7/home/ibm/AMIT/PARNCL/PARNCL1/PARNCL/bin. Yes you are
>correct, parncl binary is created under bin directory. However, while
>executing the binary I am getting below error:
>cgm2ncgm findg MakeNcl ncargfile ncarvversion ng4ex
>pre2ncgm ras2ccir601 rasview wrapit77
>ConvertMapData fontc med ncargpath ncgm2cgm nhlcc
>pre2ncgm.prog rascat scrip_check_input WriteLineFile
>ctlib gcaps ncargcc ncargrun ncgmstat nhlf77
>psblack rasgetpal tdpackdemo WriteNameFile
>ctrans graphc ncargex ncargversion ncl_convert2nc nhlf90
>psplit rasls tgks0a WritePlotcharData
>ezmapdemo ictrans ncargf77 ncargworld ncl_filedump nnalg
>pswhite rassplit tlocal
>fcaps idt ncargf90 ncarlogo2ps ncl_grib2nc parncl
>pwritxnt rasstat WRAPIT
>iitmlogin3:/gpfs3/home/iitmuser1/Bipin/ParNCL/parncl-1-0-0/example $
>mpirun -np 2 parncl plot_vort.ncl
>/gpfs3/gpfs7/home/ibm/AMIT/PARNCL/PARNCL1/PARNCL/bin/parncl:
>/gpfs3/gpfs7/home/ibm/AMIT/PARNCL/PARNCL1/PARNCL/bin/parncl: cannot
>execute binary file
>execute binary file
>Regards,
>Amit
>Sent: Monday, November 24, 2014 8:58:36 PM
>Hi,
> From the log it looks like the parncl executable is built and installed
>correctly in /gpfs3/gpfs7/home/ibm/AMIT/PARNCL/PARNCL1/PARNCL/bin . Can
>you send us the directory listing of the above directory (ls
>/gpfs3/gpfs7/home/ibm/AMIT/PARNCL/PARNCL1/PARNCL/bin)?
> Please note that installing ParNCL does not add the bin directory to
>your PATH (You will need to set your path correctly to use parncl -
>"export PATH=/gpfs3/gpfs7/home/ibm/AMIT/PARNCL/PARNCL1/PARNCL/bin:$PATH")
>Regards,
>Jayesh
>Sent: Monday, November 24, 2014 5:06 AM
>To: Krishna, Jayesh
>Subject: ParNCL build problems
>Hi Jayesh,
>I am building ParNCL on my RHEL 6.4 box. I referred below to build it
>from scratch:
>Link --> http://trac.mcs.anl.gov/projects/parvis/wiki/BuildingParNCL
>I am able to build all dependencies, but still not able to build 'parncl'
>binary. Please help me to correct this error and also find the attached
>logs.
>Regards,
>Amit
>_______________________________________________
>Parvis-users mailing list
>Parvis-users at lists.mcs.anl.gov
>https://lists.mcs.anl.gov/mailman/listinfo/parvis-users
More information about the Parvis-users
