[Parvis-users] parNCL binaries
Kyle Griffin ksgriffin2 at wisc.edu
Tue May 7 15:54:40 CDT 2013
Hi Mary,
I am indeed, and mostly use two different software configurations. One set
of machines is CentOS 5 with gcc/gfortran 4.1.2 (using the 64-bit RHEL5.6
gcc412 NCL binary on it), and the other is CentOS 6 with gcc/gfortran
versions 4.4.7 (using the 64-bit RHEL6.2 gcc446 NCL binary). These, or
similar, NCL binary variants have always worked on my machine without any
issue - although I'm sure the libraries needed to make the binaries for
ParNCL are a bit more extensive than those used in NCL.
Thanks for the assistance!
Kyle
Kyle S. Griffin
Department of Atmospheric and Oceanic Sciences
University of Wisconsin - Madison
1225 W Dayton St, Madison, WI 53706
Email: ksgriffin2 at wisc.edu
On Tue, May 7, 2013 at 3:06 PM, Mary Haley <haley at ucar.edu> wrote:
> Hi Kyle,
> Are you a current NCL user? If so, do you know which NCL binary was
> installed on your machine?  I'm assuming you have a 64-bit system.
> Also, do you know which versions of gcc/gfortran you have:
>    gcc --version
>    gfortran --version
> Sometimes this isn't an issue, but it's good to try to match the binaries
> with what you have for best performance.
> --Mary
> On May 6, 2013, at 1:58 PM, Kyle Griffin wrote:
> > With this willingness in mind, I'd like to second the request for a
> RHEL/CentOS 5 and/or 6 binary. I simply haven't had the time to sit down
> and build the numerous dependencies from source, but would really like to
> use the parallel aspects with my NCL scripts. I'm sure there are many
> people in this, from my experience, RHEL/CentOS dominated community, who
> would feel similar.
> > Thanks for the consideration!
> > Kyle
> > Kyle S. Griffin
> > On Mon, May 6, 2013 at 2:16 PM, Robert Jacob <jacob at mcs.anl.gov> wrote:
> > Hi Martin,
> > Yes we are willing to provide binaries for other platforms.  If you have
> a specific one in mind, let us know.  We are ultimately limited to the
> platforms we have access to.
> > Regards,
> > Rob
> > On 5/6/13 2:44 AM, Evaldsson Martin wrote:
> > Hi,
> > I'm thrilled to see the parNCL project has had another release (4th of
> April). My question is whether upcoming releases will provide binaries for
> platforms other than Ubuntu/MacOS which, to me, don't seem to be very
> prevalent in the HPC community (c.f.,CentOS/RHEL).
> > Best regards,
> > Martin
> > Martin Evaldsson, PhD
> > SMHI / Swedish Meteorological and Hydrological Institute,
> > SE-601 76 Norrköping,
> > www.smhi.se
> > Besöksadress/Street address: Folkborgsvägen 17
> > Tel: +46-11-495 8068
> > Fax: +46-11-495 8001
> > _______________________________________________
> > Parvis-users mailing list
> > Parvis-users at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/parvis-users
URL: <http://lists.mcs.anl.gov/pipermail/parvis-users/attachments/20130507/a9b40b27/attachment.html>
More information about the Parvis-users mailing list
