[Parvis-users] tourbles when addfile.
Matrix
sov_matrix at 126.com
Sat Mar 30 07:41:26 CDT 2013
Dear Professor :
Recently , we have built the ParNCL , and met with a lot of problems. Could you give me a manual about the ParNCL,please?
when we read the cam model history file with the Parncl. Some errors occurred when we use addfile( "file", "r") , as the following:
warning:Cannot change suppress close option
warning:SetOption() is not supported for this option (missingtofillvalue)
warning:SetOption() is not supported for this option (cachepreemption)
warning:SetOption() is not supported for this option (cachesize)
warning:SetOption() is not supported for this option (cachenelems)
fatal:Unable to load file
terminate called after throwing an instance of 'pargal::pargal_except'
what(): MB_FAILURE
With the NCL , the trouble doesn't occurred . I wonder if you have met with this trouble.
We used the NCO to extract some single variables to a new file. And any single 2D or 3D variable with the variable gw can be read by ParNCL .
for example :
ncks -v T,gw TH240_CAM-th.cam2.h0.0314-04.nc temp.nc
The new file temp.nc can be read by ParNCL smoothly. And any other 1D ,2D ,3D variable can be added to the new file without troubles.
We ask for your help ,thank you.
Xu, Ji
Tsinghua University.China
URL: <http://lists.mcs.anl.gov/pipermail/parvis-users/attachments/20130330/3a15d130/attachment.html>
More information about the Parvis-users
