[Parvis-users] PARVIS for AIX
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Mon Aug 12 10:40:48 CDT 2013
 Does the latest version (1.10.0) of gdal build without any errors for you? Did you try posting the question in the gdal mailing lists?
Jayesh
----- Original Message -----
To: parvis-users at lists.mcs.anl.gov
Sent: Friday, August 9, 2013 11:13:57 PM
Subject: [Parvis-users] PARVIS for AIX
Hi PARVIS support,
I tried to install PARVIS on the AIX  Power6 system and ran into errors when installing gdal.
Can I get binaries for the AIX 5.3?
bash-3.2$ uname -u
IBM,020241EB4
bash-3.2$ uname -x
AIX iitm01n2 3290346572 3 5 00C41EB44C00
bash-3.2$ gcc --version
gcc (GCC) 4.2.0
Copyright (C) 2007 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
gfortran was not installed.
Phani.
Phani Murali Krishna, Ph.D.,
Indian Institute of Tropical Meteorology,
Pune, India.
The error I am getting is...
exec: export(export,XL_CONFIG=/etc/vac.cfg.53:cc_r,NULL)
exec: export(export,XL_XLCMP_PATH=/usr/vac:/usr/vacpp,NULL)
exec: export(export,XL_COMPILER=xlc++,NULL)
exec: export(export,XL_ASMOBJFILES=/tmp/xlcAShR3wMd,NULL)
exec: export(export,XL_DIS=/usr/vac/exe/dis -o "rasterio.o" "rasterio.o",NULL)
exec: /usr/vacpp/exe/xlCentry(/usr/vacpp/exe/xlCentry,-qosvar=aix.5.3,-qlanglvl=extended,-qnoro,-qnoroconst,-qthreaded,-D_THREAD_SAFE,-D__VACPP_MULTI__,-D_AIX,-D_AIX32,-D_AIX41,-D_AIX43,-D_AIX50,-D_AIX51,-D_AIX52,-D_AIX53,-D_IBMR2,-D_POWER,-q64,-qlargetype,-g,-I/gpfs2/home/rphani/PARVIS/software/gdal-1.9.2/port,-I/gpfs2/home/rphani/PARVIS/software/gdal-1.9.2/gcore,-I/gpfs2/home/rphani/PARVIS/software/gdal-1.9.2/alg,-I/gpfs2/home/rphani/PARVIS/software/gdal-1.9.2/ogr,-I/gpfs2/home/rphani/PARVIS/software/gdal-1.9.2/ogr/ogrsf_frmts,-DOGR_ENABLED,-I/gpfs2/home/rphani/PARVIS/software/gdal-1.9.2/port,-I/gpfs1/scientific_appln/netcdf/netcdf-4.1.1/include,-I/gpfs2/home/rphani/PARVIS,-I/gpfs2/home/rphani/PARVIS/include,-I/gpfs2/home/rphani/PARVIS,-I/gpfs2/home/rphani/PARVIS/include,-I/gpfs2/home/rphani/PARVIS,-I/gpfs2/home/rphani/PARVIS/include,-I../frmts/gtiff,-qasm_as=/bin/as,-qcpp_stdinc=/usr/vacpp/include:/usr/include,-qc_stdinc=/usr/vac/include:/usr/include,-orasterio.o,rasterio.
 cpp,/tmp/xlcW0hR3wMa,/tmp/xlcW1hT3wMb,/dev/null,/tmp/xlcLhR3wMeF.lst,/dev/null,/tmp/xlcW2hR3wMc,NULL)
"rasterio.cpp", line 966.9: 1540-0274 (S) The name lookup for "GDALCopyWordsT" did not find a declaration.
"rasterio.cpp", line 966.9: 1540-1292 (I) Static declarations are not considered for a function call if the function is not qualified.
"rasterio.cpp", line 959.13: 1540-0700 (I) The previous message was produced while processing "<unnamed>::GDALCopyWordsFromT<double>(const double * const, int, bool, void *, GDALDataType, int, int)".
"rasterio.cpp", line 1279.9: 1540-0700 (I) The previous message was produced while processing "GDALCopyWords(void *, GDALDataType, int, void *, GDALDataType, int, int)".
"rasterio.cpp", line 959.13: 1540-0700 (I) The previous message was produced while processing "<unnamed>::GDALCopyWordsFromT<float>(const float * const, int, bool, void *, GDALDataType, int, int)".
"rasterio.cpp", line 1274.9: 1540-0700 (I) The previous message was produced while processing "GDALCopyWords(void *, GDALDataType, int, void *, GDALDataType, int, int)".
"rasterio.cpp", line 959.13: 1540-0700 (I) The previous message was produced while processing "<unnamed>::GDALCopyWordsFromT<int>(const int * const, int, bool, void *, GDALDataType, int, int)".
"rasterio.cpp", line 1269.9: 1540-0700 (I) The previous message was produced while processing "GDALCopyWords(void *, GDALDataType, int, void *, GDALDataType, int, int)".
"rasterio.cpp", line 959.13: 1540-0700 (I) The previous message was produced while processing "<unnamed>::GDALCopyWordsFromT<unsigned int>(const unsigned int * const, int, bool, void *, GDALDataType, int, int)".
"rasterio.cpp", line 1244.9: 1540-0700 (I) The previous message was produced while processing "GDALCopyWords(void *, GDALDataType, int, void *, GDALDataType, int, int)".
"rasterio.cpp", line 959.13: 1540-0700 (I) The previous message was produced while processing "<unnamed>::GDALCopyWordsFromT<short>(const short * const, int, bool, void *, GDALDataType, int, int)".
"rasterio.cpp", line 1264.9: 1540-0700 (I) The previous message was produced while processing "GDALCopyWords(void *, GDALDataType, int, void *, GDALDataType, int, int)".
"rasterio.cpp", line 959.13: 1540-0700 (I) The previous message was produced while processing "<unnamed>::GDALCopyWordsFromT<unsigned short>(const unsigned short * const, int, bool, void *, GDALDataType, int, int)".
"rasterio.cpp", line 1234.9: 1540-0700 (I) The previous message was produced while processing "GDALCopyWords(void *, GDALDataType, int, void *, GDALDataType, int, int)".
"rasterio.cpp", line 959.13: 1540-0700 (I) The previous message was produced while processing "<unnamed>::GDALCopyWordsFromT<unsigned char>(const unsigned char * const, int, bool, void *, GDALDataType, int, int)".
"rasterio.cpp", line 1229.9: 1540-0700 (I) The previous message was produced while processing "GDALCopyWords(void *, GDALDataType, int, void *, GDALDataType, int, int)".
unlink: /tmp/xlcAShR3wMd
unlink: /tmp/xlcLhR3wMe
unlink: /tmp/xlcW0hR3wMa
unlink: /tmp/xlcW1hT3wMb
unlink: /tmp/xlcW2hR3wMc
gmake[1]: *** [rasterio.lo] Error 1
gmake[1]: Leaving directory `/gpfs2/home/rphani/PARVIS/software/gdal-1.9.2/gcore'
Parvis-users mailing list
Parvis-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/parvis-users
More information about the Parvis-users
