pnetcdf check errors
Wei-Keng Liao wkliao at northwestern.edu
Fri Jun 20 11:22:41 CDT 2025
Hi, Brian
For compilation/run technical issues, the best is to create a Github issue
on PnetCDF's github repo at https://urldefense.us/v3/__https://github.com/Parallel-NetCDF/PnetCDF__;!!G_uCfscf7eWS!ZJJGHWmnm-zJrEPJlEB_dTEHw4GxEs2M0FSmFc1lJW01nB-ILT_P-9jdQ5iprv80mpXX7Med1yR0YHBZeRQsvSdLGHs66-c$
When you do that, please also provide the output file of configure command,
"config.log". It can help diagnose the problem.
Wei-keng
On Jun 18, 2025, at 11:22 AM, Brian Zelt <Brian.Zelt at gov.ab.ca> wrote:
This Message Is From an External Sender
This message came from outside your organization.
# TOTAL: 57
# PASS:  53
# SKIP:  0
# XFAIL: 0
# FAIL:  4
# XPASS: 0
# ERROR: 0
.. contents:: :depth: 2
FAIL: inq_num_varsf
[vnl2222:00000] *** An error occurred in MPI_Comm_rank
[vnl2222:00000] *** reported by process [3727425536,0]
[vnl2222:00000] *** on communicator MPI_COMM_WORLD
[vnl2222:00000] *** MPI_ERR_COMM: invalid communicator
[vnl2222:00000] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
[vnl2222:00000] ***    and MPI will try to terminate your MPI job as well)
FAIL inq_num_varsf (exit status: 5)
FAIL: inq_recsizef
[vnl2222:00000] *** reported by process [2805137408,0]
FAIL inq_recsizef (exit status: 5)
FAIL: test_vardf90
[vnl2222:00000] *** reported by process [3944153088,0]
FAIL test_vardf90 (exit status: 5)
FAIL: varn_real
[vnl2222:00000] *** reported by process [568328192,0]
FAIL varn_real (exit status: 5)
Thanks
...Brian
Classification: Protected A
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20250620/db17a938/attachment-0001.html>
